- Thank you received: 1
Weird behaviour of Add to cart and product view
- kontakt@friesbureau.dk
10 years 11 months ago #224699
by kontakt@friesbureau.dk
-- Joomla version -- : 3.4.1
I have this problem:
When I add a product to cart, the popup is not reacting as normal. Instead of adding the product to the cart - it displays another view of the website in the popup, as well as in the cart view.
Best regards
Carsten
Best regards
Carsten
10 years 11 months ago #224704
Replied by nicolas on topic Weird behaviour of Add to cart and product view
This seems something related to the SEF settings on your website.
Can you provide a screenshot of the settings in the SEF section of the HikaShop configuration ?
What if you download again the latest version install package from our website and install it on your website, does that help ?
10 years 11 months ago #224749
Replied by kontakt@friesbureau.dk on topic Weird behaviour of Add to cart and product view
Hi Nicholas
Yes it is truly strange. Attached are screenshots of SEF settings in Hikashop and Joomla Global Configuration.
Do you think it is a javascript conflict?
Best regards
Carste
Best regards
Carste
10 years 11 months ago #224752
Mmm. It's probably linked to the "activate mini URL" setting that you have in the HikaShop configuration. Try turning it on.
The following user(s) said Thank You: kontakt@friesbureau.dk
10 years 11 months ago #224811
Yes it works now. Thank you
10 years 11 months ago #224840
Subsequently i received an error 500. I looked it up in the Developer Tools Console.
"Failed to load resource: the server responded with a status of 500 (Layoutet registration_form ikke fundet.)" Translated = Layout registration form not found.
Maybe I have to transfer a new installation manually via ftp?
10 years 11 months ago #224860
Mmm. That layout doesn't exist.
So it might a problem with your template.
Try renaming the folder templates/YOUR_TEMPLATE/html/com_hikashop/user/ via FTP and see if that helps.
10 years 10 months ago - 10 years 10 months ago #225091
Can you take a look. I am not sure that I understand what I should do.
Last edit: 10 years 10 months ago by nicolas. Reason: please never post your credentials on a public forum
10 years 10 months ago #225111
In the FTP you provided the issue comes from the file /templates/gk_fest/html/com_hikashop/user/registration.php
which has been incorrectly customized by the template. I've renamed it to registration_.php and that should fix the problem.
So the problem was indeed coming from your template, not HikaShop.
