Show Products without prices
10 years 9 months ago - 10 years 9 months ago #225250 by Andrea1966
-- URL: 2015.baustoffservice-muehlner.de
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.5.26
-- Error-message(debug-mod must be tuned on) -- : No Error Massage
Hallo,
I have installed hikashop first time and will use it without shoppingcart and prices. So I did the settings in the configuration but in the product listing is still shown the price. How can I change this?
I have onley one product at this time under categorie "Befestigungstechnik".
Last edit: 10 years 9 months ago by Andrea1966.
10 years 9 months ago #225254 by Xavier
Replied by Xavier on topic Show Products without prices
In Configuration > Display > Default parameters for products you can disable the option "Display price" (not sure this is the corresponding option on your screenshot), and if that does't work so you potentially have to edit the settings of your menu/module displaying that product listing.
The following user(s) said Thank You: Andrea1966
10 years 9 months ago #225287 by Andrea1966
Hi Xavier,
Thanks for your answer. The setting of the menu was the problem. I did not saw, that there is also a tab with settings for the
products. :blush: Everything is fine now.
Best regards.
Andrea :)
Time to create page: 0.207 seconds
