Help with RegExp for Date
- pippasoup@gmail.com
10 years 7 months ago #229279
by pippasoup@gmail.com
Help with RegExp for Date was created by pippasoup@gmail.com
-- HikaShop version -- : HikaShop Business: 2.6.1
-- Joomla version -- : Joomla! 3.4.8
-- PHP version -- : 5.5.10
I've created a custom text field for a date (format: dd/mm/yyyy) and trying to write
a regexp to catch those that don't match. Not sure how it should be formatted
within the custom field screen. The field is required, so regexp should be checked.
10 years 7 months ago #229288
Replied by nicolas on topic Help with RegExp for Date
It depends what you want to check exactly. For example, you could write:
/^[0-9][0-9]/[0-9][0-9]/[0-9][0-9][0-9][0-9]$/
The following user(s) said Thank You: pippasoup@gmail.com
10 years 7 months ago #229401
Replied by pippasoup@gmail.com on topic Help with RegExp for Date
I tried that, but it doesn't recognize the string as valid. I see that its expecting
dd/dd/dddd (d=digit/number). Images shows the error appear when a valid string
is entered and the backend setup of the field (with the regexp).
I'm confused!
I'm confused!
10 years 7 months ago #229448
Got it fixed.
Drop the / .... /
as part of the expression.
Drop the / .... /
Time to create page: 0.146 seconds
