- Thank you received: 3
spacing between products is off
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : sarari 9.0
This is a category product page with the top text coming from the category description. The information is exactly how I wish it to be except for the spacing. You'll have to login to the system to see the page. Each product has massive spaces in between. Those spaces aren't uniform either. Not sure what is going on. If I could take those out, I'd be thrilled. Happy to PM you login credentials.
I'd also love to change the margins top and bottom inside the boxes.
Thank you for your assistance.
We would indeed need to be able to see the page to be able to answer you.
Please use our contact form to send us the access along with a link to this thread:
Please edit the view "product / listing_list" and remove the code:
I receive this message via PM system from notnilla :
Thank you for putting up the picture-- what file is that from? Was that looking at the code in a web browser or is that the from the file under view product, listing_list?
And so, thanks to note that for everybody can follow thread, the Hikashop Team will not give any answer via the PM way.
Anyway, this screenshot show the "Inspect" browser tool that allow to see the html code use to displayed your website.
So, yes you can see part of your "product / listing_list" view.
Here, this screenshot allow me to tell you, that the "data-consistencyheight" wasn't deleted.
If you want solve your issue remove from view "product / listing_list" and remove the code:
"data-consistencyheight".
sorry for hijacking this thread but I thought I have the same issue on my page I am trying to migrate to. Here: power.eleiko.sk/eshop/trhacky-haky
The product display is very strange, Could you please give me a hint what the issue could be? I tried to delete the "data-consistencyheight" but with no change.
Thank you
EDIT:Ok, I have solved it. I just picked in Front-end CSS File : "Default" and it is working nicely.
I have solved it. I just picked in the configuration - Front-end CSS File : "Default" and it is working nicely.
