Automatically unpublish products
10 years 8 months ago #232796 by rcadmin
-- Joomla version -- : 3.4.8
Can we automatically unpublish products that are no longer available?
10 years 8 months ago - 10 years 8 months ago #232800 by kyratn
I would like to know it too. I think this can be done with mass action help. A tutorial would be welcome. How to unpublish product when quantity gets to 0...
Last edit: 10 years 8 months ago by kyratn.
10 years 8 months ago #232804 by rcadmin
Maybe one could run a cron job then.. but what would it look like?
10 years 8 months ago #232806 by korzo
Here is mass action to unpublish product when quantity is changed to 0.
But it's very bad practice to unpublish products.
10 years 8 months ago #232809 by kyratn
Korzo thanks for share. Why would you say it is bad practise?
10 years 8 months ago #232814 by korzo
I did a case study on this subject and it has negative impact on SEO.
When product is unpublished, Hikashop display soft 404, what is generally an empty page.
Visitors landing on such page tend to leave site immediately.
Google has problem identifying such pages as error pages which leads to a lot of duplicate content. declining crawl rate and number of indexed pages.
10 years 7 months ago #233876 by rcadmin
Hi, ours is jut a school shop so SEO is not an issue. We don't use quantity so need it done based on availability date i..e once the date is past the product must be unpublished,
10 years 7 months ago - 10 years 7 months ago #233924 by korzo
You have to set up cron task to run this mass action periodically
www.hikashop.com/support/documentation/i...ashop-cron-task.html
Last edit: 10 years 7 months ago by korzo.
The following user(s) said Thank You: rcadmin
10 years 7 months ago #233886 by nicolas
So the mass action provided by korzo should do the job.
10 years 7 months ago #234000 by rcadmin
Thanks, I had not seen Korzo's bulk actions.
10 years 2 weeks ago #254081 by river
Hikashop 2.6.4
1. Is it possible to use this mass action for products with variants ?
2 ..and also make it unpublish the main product when all the variants are sold out ?
10 years 2 weeks ago #254082 by Jerome
Regarding the mass-action system, it won't be possible because you will need to check every variants and it can be done using several SQL queries and multiple checks.
In that case, a custom plugin will be required.
