Problem in show product after update
10 years 7 months ago #234310
by pishtaz13
Problem in show product after update was created by pishtaz13
Hello friends
I installed the new version, I'm in trouble ....
Products can not be displayed
All settings
In the menu've done
I am grateful for help
Pictures attached for further assistance
All settings
In the menu've done
10 years 7 months ago #234318
Replied by nicolas on topic Problem in show product after update
Go in the Joomla menu manager and edit your menu item settings. There, check that the settings of the products listing are correct.
If you don't find the issue, please provide a link to the page and a screenshot of the settings of the menu item.
The following user(s) said Thank You: pishtaz13
10 years 7 months ago #234352
by pishtaz13
Replied by pishtaz13 on topic Problem in show product after update
Hi Nicolas ,
I have all the settings related to products and categories such as former've done
I've tested several times with different options
Upon returning to version 2.6.0 to fix the problem
10 years 7 months ago #234366
by pishtaz13
Erorr
You have an override on the view 'category / listing' so the settings under the tab 'Product Options' will potentially not be used. Please backup your modifications and delete the override.
this erorr showing in Category Menu and after saving ! setting change automated!
this is my problem
this is my problem
10 years 7 months ago #234368
You need to do as the error tells you. Go in the menu Display>Views, search for the "listing" file of the "category" view and click on the "remove customization" icon for that view file and that will fix the problem, which actually comes from your Joomla template or a customization you made to that view file.
