Css issues alignment issues missing components
- mcsdesigner
10 years 7 months ago - 10 years 7 months ago #234434
by mcsdesigner
Css issues alignment issues missing components was created by mcsdesigner
www.militarycuts.com
-- HikaShop version -- : HikaShop Essential: 2.6.1
-- Joomla version -- : Joomla! 3.4.8 Stable
-- PHP version -- : 5.5.29
Hello, I seem to be having issues with the display in my product area.
I changed the value to 20 pieces instead of unlimited and the add to cart button disappeared 20 in stock is here but you can't add to cart. image 1
I changed quantity back to unlimited but now the add to cart is out of alignment any ideas on how to fix it? image 2
Also I found these problem, some other css trying to get through when I am only issuing 1 product available image 3
and out of alignment when showing no products available, any ideas image 4
Last edit: 10 years 7 months ago by mcsdesigner.
10 years 7 months ago #234435
Replied by nicolas on topic Css issues alignment issues missing components
Well, the problem is that there is not enough space to display the -, the +, the quantity input field and the add to cart button in that area with the size of each elements: take.ms/lIWxf
As you can see, the add to cart button goes below and stays hidden because of that.
In your place, I would reduce the width of the quantity input field and remove the margin/padding on the add to cart button div. That would result in this: take.ms/JylkR
Then it's just about arranging the look of the different elements the way you want.
