Product Listing not Responsive
10 years 7 months ago #237207 by oscarlito
I have a product listing in Hikashop with 3 columns but when i reduced the window or view it in my smart phone it is not displaying in one column instead it is compressing the 3 products and description. How do i correct this and what is the php file associated with the product listing?
10 years 7 months ago #237232 by nicolas
It will be responsive only if the "use bootstrap design" setting is turned on in the HikaShop configuration so please make sure that this is the case.
The main file which handles the columns and rows is the file "listing_div" of the view "product" that you can edit via the menu Display>Views. I invite you to read this documentation page for more information:
10 years 7 months ago #237418 by oscarlito
Just turned on the "Use Bootstrap design" and it worked like a charm.
Thank you! :)
