Prices in Persian will be shown from right to left
10 years 6 months ago #238377 by hossein3333
After setting prices in Iranian Rials and saving it, prices will be shown from right to left. For example: IRR 6015
instead of 5106 IRR
I have installed language pack and updated it through server of hikashop.
How can I fix it?
Thank you,
10 years 6 months ago #238379 by nicolas
Can you provide a link to the page with the issue ?
10 years 6 months ago #238482 by hossein3333
Thank you for your reply. Unfortunately, I am running the website on my localhost, Otherwise I would give you access to this page. But, I have attached some screenshots to this topic.
In the picture called "Price 1", I saved prices in Iranian rials and it seems right. But, what I see on the website is shown on the picture called "Price 2". The price is exactly viceversa.
In addition, If I want to show the price without decimal, what should I do?
Thank you in adavance,
10 years 6 months ago #238499 by nicolas
Thank you for your screenshot.
As I had guessed, the problem is different. It's not vice versa. It's just the separator of the currency which is a space and thus the RTL system of the browser swap the groups.
To avoid that, edit your currency via the menu System>Currencies and remove the space for the "Groups separation" setting there.
You can also set the "International fractional digits" and the "local fractional digits" settings to 0 if you don't want decimals.
10 years 6 months ago #238606 by hossein3333
Yes, You are right. I removed the space and decimals and now is OK.
Thank you very much :)
