Error - An element with the same alias already exi
10 years 5 months ago #242850 by 42bit
-- HikaShop version -- : HikaShop Business 2.6.3 [1606131512]
-- Joomla version -- : Joomla! 3.5.1
-- PHP version -- : 5.3.29
-- Browser(s) name and version -- : Firefox 46.0.1
-- Error-message(debug-mod must be tuned on) -- : Error
An element with the same alias already exists
Error Saving
10 duplicate found!
2 duplicates: #20 #31
2 duplicates: #22 #35
2 duplicates: #36 #48
2 duplicates: #63 #65
2 duplicates: #64 #66
Duplicate queries: #31
SELECT *
FROM rtdp_hikashop_price
WHERE price_product_id = 2367
Duplicate queries: #35
SHOW TABLES LIKE 'rtdp_falang_content'
Duplicate queries: #20
SELECT *
Duplicate queries: #48
SELECT lang_id as id, lang_code as code, image as shortcode, published as active
FROM rtdp_languages
WHERE published=1
Duplicate queries: #36
FROM rtdp_languages
WHERE published=1
I've a problem whit last Hikashop's version. When I try to save some change on product item. System give me back this error: "Error - An element with the same alias already exists - Error Saving".
In attach a screenshot about this error.
10 years 5 months ago #242856 by Mohamed Thelji
Can you click on the "Check database" button via "Hikashop->System->Configuration" and test it again after the check is complete ?
Thank you.
10 years 5 months ago #242928 by 42bit
I did, but system give me the same error. What can i do?
Thank you.
10 years 5 months ago #242941 by nicolas
Then please make sure that the alias you're using in your product is not already used by another product.
It should then work fine.
The following user(s) said Thank You: 42bit
10 years 5 months ago #243016 by 42bit
Ok, Now it works. It was about alias.
Thank you!
