- Thank you received: 6
Product Module -varform.appendChild is not a funct
10 years 5 months ago #243622
by maujbigo
Product Module -varform.appendChild is not a funct was created by maujbigo
Hi, I am getting a varform.appendChild is not a function with the products module when I click add to cart.
I use 'mootools disable' plugin if that can be an indicator.
Can you please help?
10 years 5 months ago #243627
Replied by nicolas on topic Product Module -varform.appendChild is not a funct
This indicates a problem with the add to cart javascript not finding the form of the add to cart button.
Can you provide a link to the page with the issue ?
10 years 5 months ago #243727
by maujbigo
Replied by maujbigo on topic Product Module -varform.appendChild is not a funct
Thanks for the tip Nicolas.
I updated my template override and it is back working normally.
I have the site for a little while and there might being some changes in the recent updates that needed to be ported to my template override which I did and it is all good now.
