Display multiple products on product display
10 years 4 months ago #244248 by edward68
-- Joomla version -- : 3.5.1
-- Browser(s) name and version -- : firefox nightly 50.0a1
Hello, I will upgrading my version of hikashop business as soon as I have this shop template finished. Currently I have a products layout format on the main shop page which displays images with multiple products inside (See attachment). I would like to have it so that when people click on the read more they are redirected to the product description page, which is a normal function, but I would like the product page to be able to display 1 image and add to cart button for each item from the main picture. Hope that makes sense. So for example the first image in the attached picture has a pillow, vase, cabinet, and umbrella. When you click on that you should be presented with a page that allows you to add each or all of those products, a thumbnail of each image and a short description of each image. I would love to know the easiest way to achieve this. Thanks in advance.
10 years 4 months ago #244265 by Xavier
I think that what you are looking for is a redirection to a default HikaShop product listing when clicking on one of these images.
You can create a HikaShop product listing using a desired layout, I think that the layout "listing_img_desc" of the "div" type will be the best.
That way, all the product will be displayed on the same page with add to cart button, the description and a thumbnail.
To point to that menu, you will have to edit the view used for the current listing and add html code for a button with the correct link to that menu (so with the correct alias).
10 years 4 months ago #244881 by edward68
Hi Xavier, Thank you so much for the advice. I will give that a try. I really appreciate your help and the speedy response. I look forward to the upgrade soon too. I cant wait to see how it all works with the upgrade in place.
