Problem with CONTACT_US_FOR_INFO
10 years 2 months ago #246613 by verde
-- Joomla version -- : 3.6.0.
-- PHP version -- : 7
In product page use CONTACT_US_FOR_INFO, i have 2 problem.
1. After click to OK button send email, but not show a system message, for example: "Message sent or thank you for e-mail"
2. When i get a mail with contact info, the product url link refer for the backend product page.
Could you help me to solve this problem?
Sorry for my bad english.
10 years 2 months ago #246616 by Jerome
I'm sorry but I don't see any bug or problem here.
The contact form is send to the administrator who have an access to the backend and should access to all backend elements (products, customer, orders, etc).
So I'm afraid that I can't help you for a problem that I can't understand.
10 years 2 months ago #246913 by verde
Hi! thanks for reply Not bug, but problem.
1. I’ve got the following problem: If a potential buyer sends a message, they don’t get any feedback wheather the message has been sucessfully sent. Is it possible to set up this function?
2. If I answer the mail of a potential buyer and they click on the link of the product that they find it the letter, they get to the backpage of the administrator where they won´t be able to check on the product before buying it. Is it possible to modify the link in the letter so that the potential buyer gets to the frontend page?
10 years 2 months ago #246918 by nicolas
1. There is a message displayed to the user that the message has been sent. If you don't see it, it means that your template is hiding it:
www.hikashop.com/support/documentation/6...tibility-issues.html
2. You would have to edit the "contact" email via the menu System>Emails (business edition) in order to change the link.
The following user(s) said Thank You: verde
10 years 2 months ago #246946 by verde
Hi Nikolas,
The first problem is solved, thanks!
But in the mail setting I do not know what amount to set
These my settings
http://imgur.com/qokpl1h
http://imgur.com/82ixI5l
10 years 2 months ago #246952 by Jerome
Which email setting ?
Like Nicolas wrote in his message, he explained that with HikaShop Business you can edit the email content in order to change the content (so the link into) ; but there is not setting, there was never any mention of that.
10 years 2 months ago - 10 years 2 months ago #247117 by verde
Sorry! Im found it this place in system menu. Could you help me, what change in HTML version?
In sender infromation found this code, this should be rewritten?
$admin_product_url = JRoute::_('administrator/index.php?option=com_hikashop&ctrl=product&task=edit&cid[]='.$data->product->product_id, false, true); $productClass = hikashop_get('class.product'); $productClass->addAlias($data->product); $front_product_url = hikashop_frontendLink('index.php?option=com_hikashop&ctrl=product&task=show&cid='.$data->product->product_id.'&name='.$data->product->alias.$url_itemid);
Last edit: 10 years 2 months ago by Jerome. Reason: [code] is nice
10 years 2 months ago #247124 by Jerome
Regarding the "preload" content, it already propose two variables for the two links.
So in the HTML part, you need to replace the tag
{VAR:PRODUCT_DETAILS}
By the tag
{VAR:FRONT_PRODUCT_DETAILS}
10 years 2 months ago #247150 by verde
thank you for your patience
Time to create page: 0.192 seconds
