Associate Product with English and Chinese
10 years 3 months ago #246635 by andreas@ifoundries.com
Hi Expert,
I have 2 categories, one is for Chinese, and one is for English.
Associating the category is ok since I can do it in Menu Manager level. However, problem occurs when you are in Product Level. I do not know how to associate together between Products.
10 years 3 months ago - 10 years 3 months ago #246655 by Mohamed Thelji
Hello !
Can you give us more information about it through some screenshots for example ?
Thank you !
Last edit: 10 years 3 months ago by Mohamed Thelji.
10 years 3 months ago #246796 by andreas@ifoundries.com
Hi Mohamed,
I attached the front-end so that you understand the problem. When I do changes languages from either English or Chinese, It always never brings me to that chinese version of that book.
As I wrote before, I made this structure for 2 categories (1 is for English, and 1 for Chinese). To relate category was ok. However, I cannot relate it to Product Level.
10 years 3 months ago #246821 by nicolas
Did you create two different categories listing menu item (one for each language category) and then linked them to their corresponding language and linked them together in the Joomla menu manager ?
That way, the menu system will switch you from one menu item to the other when you switch the language.
I would however recommend to not use this system and instead have only one set of categories, one set of products, one set of menu items, and install the Falang extension to translate them all. Falang will then automatically load the correct translations when you switch the language. It's much more straight forward and simpler to setup and maintain in the long run.
