How to make products display in sub cat only
10 years 3 months ago #247324 by PigeonTech
-- Joomla version -- : 3.6.2
-- PHP version -- : 5.6
I've just upgraded to Hikashop 2.6.3 and see the menu options under Display are missing 'Content Menu' and 'Content Module'. I'm not sure if this is causing the problem I have as I would normally used these to configure the modules.
The problem I have is products in sub categories are displaying in the main categories which I don't want. This can be seen in the example page www.edmcmullan-sectionphotographystore.co.uk/berwyn
In the updated Hikashop how do I make products display in the sub category only?
10 years 3 months ago #247328 by nicolas
It's the same "sub element filter" setting of the products listing that you can change.
It's now easier than ever. Just edit your menu item via the Joomla menu manager, and change that setting under the "products options" tab there.
Time to create page: 0.040 seconds
