Product "Order" column not functional
10 years 3 months ago #247552
by Saunders
Product "Order" column not functional was created by Saunders
www.uvgear.elements-chartreuse.co.uk/index.php/uvdecorations
-- Joomla version -- : 3.5.1
I am unable to change the order of products in Hikashop component as I want to order the products in each category. I was able to do this before, but somehow when I now click on the order column, there is no response from the system. I don't get to see the check boxes and/or an option to move the item up or down.
I read in various support posts that this had happened to others, but do not see what the action required was?
Any ideas please?
Attached snapshot of the backend.
Any ideas please?
10 years 3 months ago #247556
by lousyfool
Replied by lousyfool on topic Product "Order" column not functional
Indeed, you cannot order the products if the listing is set to "All sub elements". So, change it to "Direct sub elements", and you'll be able to order manually.
