Having display issues on product display
- keeperofthetux
10 years 1 month ago #250332
by keeperofthetux
Having display issues on product display was created by keeperofthetux
10 years 1 month ago #250404
Replied by nicolas on topic Having display issues on product display
It must be related to the CSS of your template. If you switch to the default template of Joomla, it should display fine right ?
So in that case, we would need to directly look at the page on your website to analyse the CSS and tell you what to do exactly.
- keeperofthetux
10 years 1 month ago #250425
by keeperofthetux
Replied by keeperofthetux on topic Having display issues on product display
@nicolas: thank you for this input. I will try it out. If it won't work. I will have to upload the complete site to an online server.
I will get back to you soon.
10 years 2 weeks ago #253638
by jimmyngf
Replied by jimmyngf on topic Having display issues on product display
I have a same problem , can you help me fix this problem. but how can i put the description under the picture. thanks
10 years 2 weeks ago #253675
My answer is the same :
And you didn't provide the URL so that we can look at your page.we would need to directly look at the page on your website to analyse the CSS and tell you what to do exactly.
The following user(s) said Thank You: jimmyngf
