category/product display is not mobile friendly
10 years 1 month ago #251109 by artspara
1.product list has a fixed width and is not mobile friendly.How can remove the inline width attribute so I can define the width in my template css?
10 years 1 month ago #251126 by nicolas
If you activate the "use bootstrap design" setting of the HikaShop configuration and that your template is bootstrap compatible, it should be mobile friendly automatically.
www.inmotionhosting.com/support/edu/joom...mplate/add-bootstrap
