select more products in a passage, on a page
- giuseppe123456
9 years 10 months ago #258319
by giuseppe123456
select more products in a passage, on a page was created by giuseppe123456
www.topwebsite.it/servizi-web-sassari-e-...nazioni-on-line.html
-- Joomla version -- : 3.6
hello, I would like to make a list of products on a page and get a chance to put in the basket more items by choosing the amount and make a general check-out.
for example, on a page I must be able to select them 2 pizzas of one kind, 3 of another kind pizzas and make a general check-out.
currently I have to select a product and go back to try other products.
I do this for a restaurant that offers an online menu.
thank you
linklink
thank you
linklink
9 years 10 months ago #258341
Replied by nicolas on topic select more products in a passage, on a page
You want to change the "Display the quantity field on the product page" setting of the HikaShop configuration to "global on listing" and turn on the "add to cart" setting of your menu item if that's not already the case.
The system will then automatically display one quantity input for each product on the listing and one main add to cart button.
- giuseppe123456
9 years 10 months ago #258354
by giuseppe123456
Replied by giuseppe123456 on topic select more products in a passage, on a page
ok thanks, but I need after "add to card" to be able to continue your purchase, do not go to the final basket, I would point you decide whether to continue shopping or go to checkout
- giuseppe123456
9 years 10 months ago #258355
by giuseppe123456
9 years 10 months ago #258358
Then you also want to change the "After a product is added to the cart" setting of the HikaShop configuration to something else than "always go to the checkout".
