- Thank you received: 1
Additional product images thumbnails not displaying
- NanoPlanet
9 years 10 months ago #258693
by NanoPlanet
Additional product images thumbnails not displaying was created by NanoPlanet
ojoelmercado.com/ojo-collection/tee-shir...embroidered-logo-tee
-- Joomla version -- : 3.6.5
Good morning,
I received an email over the holiday from a client running HikaShop on their website. If you look at
and select any of the variants from the dropdown, you will see that the main product photo changes
accordingly.
That part functions fine.
The problem that has arisen is that they have also added additional product images (Product tab,
Images & Files panel) but those additional product thumbnails are not displaying. They display
fine on products that do not have variant dropdowns.
How do I fix this?
Many thanks!
Good morning,
accordingly.
How do I fix this?
Many thanks!
9 years 10 months ago #258695
Replied by nicolas on topic Additional product images thumbnails not displaying
I've never heard of such issue.
Try with the default template of Joomla, does it work ?
Also, could you provide a screenshot of the settings for the product of your link ?
Could you also provide a link to a product without variants for which it works ?
- NanoPlanet
9 years 10 months ago #258747
by NanoPlanet
Replied by NanoPlanet on topic Additional product images thumbnails not displaying
No matter what template I use, the problem persists.
Here is a product without a variant dropdown. You can see that the additional product image thumbnails display fine:
ojoelmercado.com/jewelry/browse-all/prod...-earrings-by-shaesby
The product with the thumbnail display problem is:
I have attached 2 images for this product. The first is the product tab settings. The second is the variant tab.
9 years 10 months ago #258749
by Jerome
Replied by Jerome on topic Additional product images thumbnails not displaying
There is no problem at all.
The first product have two images.
The second product have one image per variant.
If you change the variant the thumbnail can also change.. But because all of your variants have images, the images of the main product are not used, they are overriden.
- NanoPlanet
9 years 10 months ago #259007
by NanoPlanet
So if a product has variants and images assigned to those variants, there is no way to also display
additional images NOT assigned to variants below the main image?
9 years 10 months ago #259014
by Jerome
If the variant do not have any image ; all images of the main product will be used.
If the variant have images ; these images will be used.
