Problem with mobile...
9 years 10 months ago - 9 years 10 months ago #258830 by rober1903
-- HikaShop version -- : 3.6.4
-- Joomla version -- : 3.6.5
-- PHP version -- : 3.6
I attach 2 captures of my mobile.
1. How can I solve that there is not so much space between the photo and the name, please.
2. I need everything to be centered please.
Thank so much for your help.
Last edit: 9 years 10 months ago by rober1903.
9 years 10 months ago #258851 by nicolas
Replied by nicolas on topic Problem with mobile...
Try turning on the "use bootstrap design" setting of the HikaShop configuration.
It should already help make your listings responsive.
9 years 10 months ago #258886 by rober1903
Replied by rober1903 on topic Problem with mobile...
Hi.
I don´t know where I must change this.
Thanks!!!
9 years 10 months ago #258888 by nicolas
As I said, it's in the HikaShop configuration page. It's under the Display tab:
www.hikashop.com/support/documentation/5...html#display_general
9 years 10 months ago #258983 by rober1903
For the movile it works perfectly. What should I do to center the button and the amount?But in the computer is seen in column.
How can I solve this, please?
I'll send you attachment of the configuration.
Thanks so much !!!
Regards !!
9 years 10 months ago #258986 by nicolas
I don't see what you're talking about on the link you provided before.
Could you provide a link where we can see the issues you're talking about ?
9 years 10 months ago #259037 by rober1903
The link is: adevaehijos.com
9 years 10 months ago #259065 by nicolas
Your Joomla template is missing the Bootstrap CSS.
You'll have to add it to it so that ht can display properly:
www.inmotionhosting.com/support/edu/joom...mplate/add-bootstrap
For the quantity input field not being aligned, you can remove that CSS:
.hikashop_product_quantity_input_div_default {
vertical-align: middle;
in the HikaShop frontend CSS in the Display tab of the HikaShop configuration.
9 years 10 months ago #259159 by rober1903
I added bootstrap to the template. (new.adevaehijos.com).
In mobile is perfect but in pc version the categories and products in column 1. I want to see in 3 colmuns.
9 years 10 months ago #259160 by Jerome
Replied by Jerome on topic Problem with mobile...
I'm afraid that there is no Bootstrap 2 in your template.
In any case, the usage of HikaShop 3 should fix all that kind of problem because it includes his own responsive grid system.
