Specifications on product view for multi lingual website
9 years 10 months ago #259071 by svjatoslavs.krasnikovs
-- Joomla version -- : 3.6.4
Yo community. I'm attempting to build a website for a client in order to propose switching from Virtuemart (ehh) to Hikashop. I am building bi lingual website with Latvian and Russian languages. I am using Falang. Everything seems to work (all content is working perfectly, like custom fields/bi lingual product description and multi lingual search). The one last bit I need to get working is the following:
I need to have multi lingual tabs. In the screenshot below you can see a tab called "Apraksts" , in Latvian it's product description, and it works in both Latvian and Russian, like you can see in the screenshots below. The right tab (Specification) appeared out of nowhere (John Cena refference...) in latvian it's "Specifikācija" ("'Характеристики"' in Russian). Even thou I don't recall creating it, I still need that Specification tab. Basically the idea is that there will be a multilingual tab with description (got it working now) and a multilingual tab with specifications (i dont know how, but the tab is there but I have no idea how to edit it). Can you please help me ?
[img
[img
[img
9 years 10 months ago #259080 by nicolas
The specification tab is added automatically when you have custom product fields configured so that the system can display the value you entered in these fields in that tab.
So if it's empty, it means that you've created custom product fields for your products but you didn't enter anything in these fields for that product yet.
9 years 10 months ago - 9 years 10 months ago #259094 by svjatoslavs.krasnikovs
Weird thing is that I do not have any custom fields made apart from the "shortproductdescription" but I've chosen not to display it on the product page. Here's the list of my custom fields.
[img
Last edit: 9 years 10 months ago by svjatoslavs.krasnikovs.
9 years 10 months ago #259123 by nicolas
It's probably that. Try deactivating it and the tab should disappear.
Also, try :
- editing the custom field and saving it.
- renaming the folder templates/YOUR_TEMPLATE/html/com_hikashop/product if you have it.
