- Thank you received: 1
Radio Button not displaying in product listing.
9 years 9 months ago #260571
by elktis
Radio Button not displaying in product listing. was created by elktis
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.6.29
Dear Sir.
I don't know what i am doing wrong.
I need to put radio buttons in selections of products .
I have for example e computer as a product and also i have characteristics as RAM, Hard Disk, etc...
RAM a 1GB, RAM b 2GB... etc..
also Hard Disk a 100 Gb , b 500 Gb.. etc...
Of course the total price is depends from the selection.
I crate drop down but its not useful, cause i want the user to see with one look the possible options.
If i put characteristics on the product page, i need to add many variables and this is not useful and difficult to set .
Dear Sir.
9 years 9 months ago #260574
Replied by nicolas on topic Radio Button not displaying in product listing.
There is no option to change option dropdowns to radios and indeed, the characteristic radios are not a good solution for managability in your case.
So you would have to edit the file "option" of the view "product" via the menu Display>Views and change the code to display radios instead of a dropdown. The JS code there will have to be adapted as well.
If you're not a developer, you'll have to ask one to do that for you.
9 years 9 months ago #260635
by elktis
Replied by elktis on topic Radio Button not displaying in product listing.
Thank you for reply Nicolas.
As your opinion, i think is good not to use the "radio" type button, in my case.
But i think that sometimes the customers wants to see with a first look what the product also contains without using dropdown menu.
So, as about the code editing, no i will leave it as it is.
Thank you for the reply.
Time to create page: 0.102 seconds
