Related product title not displayed
9 years 9 months ago #262526
by ricardo
Related product title not displayed was created by ricardo
www.concret.it/menu-prodotti/locinox/ser...cine-con-kidloc.html
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.6.30
-- Error-message(debug-mod must be tuned on) -- : nothing
I've a problem after updating hikashop. Title of related products it's not displayed after the update...
thanks a lot.
Ricardo
thanks a lot.
Ricardo
9 years 9 months ago #262538
Replied by nicolas on topic Related product title not displayed
I've checked on my end but I don't have the problem.
Do you have the "show title" setting of the related products module turned on ?
Can you also switch to the default template and see if you get the title ?
It might be linked to an old view override you have.
9 years 9 months ago #262720
by ricardo
Replied by ricardo on topic Related product title not displayed
The problem is that the module is disabled but still related products appear under the item card ... without the title
9 years 9 months ago #262729
by Jerome
Replied by Jerome on topic Related product title not displayed
If you're using "modules under the product page" ; HikaShop and Joomla does not care if the module is published or not.
HikaShop is asking Joomla to display the module (thanks to his ID) and Joomla is performing the display.
9 years 9 months ago #262766
by ricardo
Hello and thanks for the reply.
Okay, but then why still it does not receive the title although the form is set as visible?
9 years 9 months ago #262773
Make sure that the "show title" setting of your related module is turned on.
If that's the case and you don't see the title, then I can only think that it comes from a view override of the template, which is why I proposed to try switching the template to see if it was related to that or not. By the way, you didn't say what was the result of that test ?
9 years 9 months ago #263066
by ricardo
Ok, done everything. Even with setting another template is displayed the title ...
9 years 9 months ago #263068
You mean "is NOT displayed" ?
If you still have the problem, please provide a backend access and a link to this thread via our contact form and we can have a look:
9 years 9 months ago #263311
by ricardo
Yes, is not displayed... ok I provide you an account...
9 years 9 months ago #263382
Download again the install package on our website and install it on yours and that will fix the problem.
The following user(s) said Thank You: ricardo
9 years 9 months ago #263401
by ricardo
Hi Nicolas, the problems is Solved!
