After upgrade 3.0.0 I have found quantity with a combo box
9 years 9 months ago - 9 years 9 months ago #262550
by ramada70
www.securgross.it
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.3.29
-- Browser(s) name and version -- : chrome 56.0.2924.87
After the upgrade I have found quantity with a combo box with a max of 15 before I have a blank box. How can I do to go back?
Antonio Macciò
Antonio Macciò
Last edit: 9 years 9 months ago by Jerome.
9 years 9 months ago #262562
by Jerome
Replied by Jerome on topic After upgrade 3.0.0 I have found quantity with a combo box
That display depends on the configuration of your website regarding the "quantity layout".
www.hikashop.com/support/documentation/5...html#display_product
9 years 9 months ago #262641
by ramada70
Replied by ramada70 on topic After upgrade 3.0.0 I have found quantity with a combo box
9 years 9 months ago #262670
by GW
Replied by GW on topic After upgrade 3.0.0 I have found quantity with a combo box
the same happened in our case, from your first image looks like you're talking about your cart module, but you can't set the type of quantity display for the cart in the configuration, you can only set the quantity for your product pages and product listings (which you show in your second post).
@Jerome: please correct me if I'm wrong
To change the quantity display of your cart module, you have to make a small change in your cart view by going to Display -> Views -> select your template -> select product -> and open the view cart. There on line 395 the quantity display is defined:
You can change the quantity display by modifying the show_select to one of the other possibilities: show_default, show_default_div, show_regrouped, show_select, show_select_price, show_simple, show_leftright, show_simplified, or show_html5.
These are the same possibilities you have for your product quantity display, you can play around with it to see which one you prefer in your cart module. Hope that helps.
$this->quantityLayout = 'show_select';
- Thank you received: 1778
9 years 9 months ago #262702
by Mohamed Thelji
Replied by Mohamed Thelji on topic After upgrade 3.0.0 I have found quantity with a combo box
Thank you for your feedback, can you download the last Hikashop version through our website, install it and test it again ?
9 years 9 months ago #262762
by GW
Hi Mohamed,
thanks for making the quantity display modification in the product/cart view, it's working fine, nice improvement!
Kind regards,
Kind regards,
9 years 9 months ago #262767
by GW
Btw, while we're talking about the product/cart view, we saw a tiny error which we didn't think worth starting a new threat for:
on line 281 the td class name hikashop_cart_module_product_total_value should be hikashop_cart_module_product_total_title
Kind regards,
Kind regards,
9 years 9 months ago #262775
Replied by nicolas on topic After upgrade 3.0.0 I have found quantity with a combo box
Thanks, we'll fix that
9 years 9 months ago #262872
by ramada70
Now it's Ok.
Thank you very much.
