Notice: Undefined variable: fieldsClass with hikashop versions after feb 25th
9 years 8 months ago #263858
by kernel64
Kind regards,
Cornel
Notice: Undefined variable: fieldsClass with hikashop versions after feb 25th was created by kernel64
www.123gebak.nl
I am getting an error message after I updated Hikashop 3.0.0.... the latest version on which the error isn't there is com_hikashop_business_v3.0.0_2017-02-25_16-13-01.tar.gz. Every version after that one has the errors:
Notice: Undefined variable: fieldsClass in /htdocs/demo/components/com_hikashop/views/product/view.html.php on line 772
Fatal error: Call to a member function addJS() on null in /htdocs/demo/components/com_hikashop/views/product/view.html.php on line 772
Can you look into that ?
Kind regards,
Cornel
9 years 8 months ago #263863
by Jerome
Replied by Jerome on topic Notice: Undefined variable: fieldsClass with hikashop versions after feb 25th
For next posts, please provide your "build number" instead of the package filename.
www.hikashop.com/support/documentation/5...onfig.html#main_main
The error you mentioned is related to a patch made by Nicolas on February 28 related to that forum post :
www.hikashop.com/forum/5-support-en-fran...u-panier.html#263648
Unfortunately, he hasn't test his patch with custom fields enabled.
I made a fix and uploaded new packages.
9 years 8 months ago #263873
by kernel64
Kind regards,
Cornel
Replied by kernel64 on topic Notice: Undefined variable: fieldsClass with hikashop versions after feb 25th
Normally i mention the package build number.
Build number where it went wrong HikaShop Business 3.0.0 [1702251124]
Just uploaded build HikaShop Business 3.0.0 [1703020039] and problem has been resolved.
Thanks for your quick response.
Kind regards,
Cornel
