price in cart problem
- ebrahimahamdi
9 years 7 months ago #264093
by ebrahimahamdi
price in cart problem was created by ebrahimahamdi
-- Joomla version -- : 3.6.5
-- PHP version -- : 7.0.3
-- Browser(s) name and version -- : firefox 47
when i add more than 1 product to my cart , it's not aable to show the sum price , for example
product price is 5$ when i order 2 , it should be 10$ but is not like that.
9 years 7 months ago #264095
Replied by nicolas on topic price in cart problem
We don't have the problem on our end.
Please provide a link to the product page and a screenshot of the settings of the corresponding product so that we can look at the issue.
- ebrahimahamdi
9 years 7 months ago - 9 years 7 months ago #264148
by ebrahimahamdi
Replied by ebrahimahamdi on topic price in cart problem
Last edit: 9 years 7 months ago by ebrahimahamdi.
9 years 7 months ago #264159
So did it work before ?
Did you change something and then it didn't work ?
What if you temporarily switch to the default template ? Does it work with it ?
- ebrahimahamdi
9 years 7 months ago - 9 years 7 months ago #264192
by ebrahimahamdi
it was working but i didn't change the setting and the template is protostar (joomla default template )
where is the special setting of this problem?
9 years 7 months ago #264212
So you're saying that it was working, and you didn't do anything but all of a sudden it doesn't work ?
That's not possible. Something must have been changed on the website around the time it stopped working.
For example, you installed something, like a third party plugin, or you change a setting in another third party extension linked to HikaShop in some way.
Do you recall anything ?
- ebrahimahamdi
9 years 7 months ago - 9 years 7 months ago #264315
by ebrahimahamdi
i checked my plugin , setting , view.display and other else but i couldn't fix it.
don't you have any opinion , where do you think that i should check or ...
i told you that it was not like this from the beginning , but i was wrong , i checked my first akeeba back up before i publish my website (i install it on local) then i understood , i have the exact problem on that backup too.
9 years 7 months ago - 9 years 7 months ago #264323
Well, I don't know what was done to be able to have that behavior and no one ever reported such behavior with HikaShop 2.6.3.
So it's hard to provide a solution...
You could try updating, but it might create other problems if you have customizations... and it might actually not fix the issue if it's not coming from a bug in HikaShop but a third party plugin interacting with hikaShop.
But that's all I can propose.
Last edit: 9 years 7 months ago by nicolas.
- ebrahimahamdi
9 years 7 months ago #264370
by ebrahimahamdi
i solve it by deleting this plugin which you have had suggested to me :
HikaShopCustom Quantity Weight plugin
Time to create page: 0.229 seconds
