- Thank you received: 1
Tabular product layout needs help
9 years 6 months ago #265002
by blackfrog
Tabular product layout needs help was created by blackfrog
-- Joomla version -- : 3.6.5
As you can see by the attached image, the description showing up under the image is being covered up by the tabs. How can this be corrected?
Second, the tabs themselves are very difficult to see... is there a way to change the color(s) of the border to each, or the background of the engaged tab to better define them?
Thanks in advance.
Thanks in advance.
9 years 6 months ago #265011
by Jerome
Replied by Jerome on topic Tabular product layout needs help
For customization procedures, please read that documentation :
If you want to customize the tabular product page ; you will be able to find some other threads in that forum talking about very similar requests.
9 years 6 months ago #265107
by blackfrog
Replied by blackfrog on topic Tabular product layout needs help
Thank you, and I will look into this link for modifying the tab colors, but what I am confused about is why the description is overlapping the tabs? This has not been modified and I would think that if a tabular layout is made available that it should not behave this way straight out of the box. Even if I reduce the text it is still overlapping. Is there a way to just turn off the description under the photo and only have it in the tab area?
9 years 6 months ago #265111
Replied by nicolas on topic Tabular product layout needs help
Hard to say for us. We don't have that problem on our end, and you didn't provide a link to the page, so all we can say is a generic answer.
In fact, by default, the small description before the tabs does not even appear as there is CSS to hide it in HikaShop by default with such CSS:
#hikashop_product_description_main_mini{ display:none; }
So this can only mean that the CSS has been modified and/or the CSS of the template is interacting with the display of the product page.
9 years 6 months ago #265174
by blackfrog
The site is off line as it is being built. Is there a secure way for me to supply you with a log in?
9 years 6 months ago - 9 years 6 months ago #265175
by Philip
Replied by Philip on topic Tabular product layout needs help
you can use our Contact us form in order to provide Url link(with display issue) and access references.
Don't forget to add an Url link to this topic in order to keep the link.
Awaiting news from you.
Last edit: 9 years 6 months ago by Philip.
9 years 6 months ago - 9 years 6 months ago #265479
by Philip
I get your access references, and I think you can correct it by adding some Css.
I guess that there is some missing Css in your template, just add this kind of css command
For add this kind of code,
see this tutorial
div#hikashop_product_description_main_mini {
margin-bottom: 25px;
Time to create page: 0.216 seconds
