Display problems on a product page
9 years 7 months ago #267593 by luwes2000
-- url of the page with the problem -- : www.primafineart.com/paintings/product/1...fboards-with-flowers
-- Joomla version -- : 3.6
I am sorry to bug you about a CSS question. Ive tried my best with google Dev tools and searching all over this form, but I can't get this page to line up correctly. I also can't get the image to be responsive. I have turned on the Boostrap but that did not solve the problem, If you can take a look I really appreciated.
9 years 7 months ago #267606 by Jerome
pasteboard.co/5GH4TSiag.png
If you force the width and the height of the image in your configuration ; it is normal that your image is not responsive because the size will be for every devices.
9 years 7 months ago - 9 years 7 months ago #267674 by luwes2000
Thank you for the reply, I think I almost got it. Can you tell me what are the css classes I need to edit to adjust the location of the price and the style of the 2 buttons.
Last edit: 9 years 7 months ago by luwes2000.
9 years 7 months ago #267701 by nicolas
I don't see what you have in your screenshot.
For me, it displays fine for all the screen sizes.
I suppose that you already found your answer.
If not please provide more information on how to reproduce what you have on your screenshot.
9 years 7 months ago - 9 years 7 months ago #267769 by luwes2000
thank you again. I am attaching a screen shoot of the final items I would like done.
1. I would like to move the price lower so its location is closer to the Add to cart button and also change the color of the price.
2. I would like to change the style of the "add to cart" button to different color and just need the CSS class.
3. I also would like to modify the "contact us" button for it to be a little lower and not touching the "Add to cart" button and I also need to change its style as well, so I also need what css class for that button as well.
Thank You
9 years 7 months ago #267770 by nicolas
Please note that this support forum is not there to provide custom CSS code.
We're happy to give hints and solve issues (real issues, when things doesn't work like it normally should). But if you want to customize things, you have to do it on your end, either yourself, or have it done by a designer.
Here is our documentation page, which explains how to edit the CSS of HikaShop, and how you find which classes to use in your CSS code to style the different elements of the page:
The following user(s) said Thank You: luwes2000
