Products Display box
9 years 5 months ago #268849 by kittdrury
-- url of the page with the problem -- : www.honeysuckleyard.com/index.php/product-type/anti-wrinkles
-- Joomla version -- : 3.7
-- PHP version -- : 5.6
-- Error-message(debug-mod must be tuned on) -- : Length of product display box.?
Is there a way to force the system to display the product boxes in the same "length" so that you always get a tidy display. If they are all the same length then they would display 3x3 or 3x4 and so on not with the odd one offset.? Can this be done.
Kitt
9 years 5 months ago #268893 by nicolas
Replied by nicolas on topic Products Display box
Yes. There is the "height consistency" setting that you ca activate in the "products options" tab of your menu item for that. In that case, some javascript will calculate automatically the height of the boxes to have them display nicely.
Alternatively, you can force their height with some CSS code.
For example:
.hikashop_subcontainer {
height: 400px;
The following user(s) said Thank You: kittdrury
Time to create page: 0.124 seconds
