[SOLVED] Module to show products in a category ALWAYS as on mobile.
9 years 5 months ago - 9 years 5 months ago #271902 by CarloG
-- Error-message(debug-mod must be tuned on) -- : no message
Hi everyone there.
I am working on a Joomla website with template JD Chicago which have Hikashop inside.
I created a module( Hikashop Content Module ) to show all the products in a category.
My setup is :
Boostrap Mode : NO from System/Display
DIV 4 columns -->( DIV INHERIT doesn't allow centered title under the image )
Image and Title ( inherit )
Text Centered : YES
And everything else is OFF and the page is perfect, silk smooth, GREAT !
Then when I go mobile...
I have the divs one on the side of the other, no pics viewable, one item out of the screen...
Then I found the solution, here, getting ' Bootstrap Mode ON ' in System.
When I do this, even on every PC and every browser,
I see a column with the products... like if my 17.3' laptop is a mobile phone.
How can I fix it ?
Thank you so much for your kind help.
Last edit: 9 years 5 months ago by CarloG.
9 years 5 months ago #271904 by nicolas
With the "use boostrap design" setting turned off, HikaShop display is not responsive.
So you indeed want to activate that.
However, it requires your template to support bootstrap 2. If, when you activate that option, you see the listing on one column, it means that your template doesn't support bootstrap 2 or not completely.
There are two solutions to that:
1. You can add the bootstrap 2 support to your template:
www.inmotionhosting.com/support/edu/joom...mplate/add-bootstrap
2. You can update your HikaShop. With HikaShop 3, your listings will be responsive without the use of that "use bootstrap design" setting.
9 years 5 months ago #271936 by CarloG
Thank you for your fast answer as always.
After posting I tried to upgrade to last version and as the upgrade went go e, all is perfect now.
Thank you again
Carlo
