Caracteristics displayed in listing products
- gabrielalittle
9 years 3 months ago #275895
by gabrielalittle
Caracteristics displayed in listing products was created by gabrielalittle
I need to show caracteristics in listing products, I road that isn't a feature but I need it. I can edit the component but I don't know where start. Can you tell me how I can do this?
9 years 3 months ago - 9 years 3 months ago #275911
by Philip
Replied by Philip on topic Caracteristics displayed in listing products
You can create an override view of your listing view (div, list or table) in your Main HikaShop Configuration, go to Display dropdown and select Views.
Use the three dropdowns filter to find concerned views with Product/ Your Template/ Front end, and depends from your Item Menu configuration select listing_div, listing_list or listing_table.
That operation will required html & php knowledge, for methodology see this tutorial to understand displaying view process, you can too switch the Display view files option to Front-end (in Main HikaShop Configuration and Advanced tab).
Hope you will succeed in what you want achieved.
Last edit: 9 years 3 months ago by Philip.
Time to create page: 0.042 seconds
