Product badge displayed in wrong place
9 years 2 months ago #276302 by adm.media
-- url of the page with the problem -- : www.organiccoffeereserve.com
-- Joomla version -- : 3.7
-- PHP version -- : 7
-- Error-message(debug-mod must be tuned on) -- : Notice: Indirect modification of overloaded property JMenuItem::$colw has no effect in /var/www/ocr/shop/plugins/system/helix/core/classes/menu.php on line 93
The badge does not appear over the product picture. Instead it shows up as yet another product picture. Any idea of how to sort it out will be appreciated. Thank you!
9 years 2 months ago #276304 by Jerome
The notice you have is related to one of your template plugin.
You should deactivate the display of such notices or contact your template provide to let him fix that.
In order to understand what cause your displaying issue we would need a link to the product page in question ; which means that we would also need an access since your website is closed/protected.
Otherwise, I can just tell you that I think the problem is related to some CSS conflict rules. I guess that one rule of the template or a third party plugin is affecting the display of the images and makes the badge not be displayed over the main product image.
So you should analyze the CSS applied on the badge to understand what external CSS rules affect its display.
www.hikashop.com/support/documentation/1...the-display.html#css
9 years 2 months ago #276336 by adm.media
I appreciate your fast reply.
I am afraid that analyzing the CSS is beyond my pay grade...
Would you please take a look at the product page:
www.organiccoffeereserve.com/shop/other-...ian-decaf-1-us-galon
I will send you logins through private message.
Thank you and regards!
9 years 2 months ago #276340 by Jerome
Can you please take a look at my forum signature ?
Thanks for you understand and please be sure that your private message as been automatically deleted.
9 years 2 months ago #276524 by adm.media
you got the point there... tricky thou...
Sent you message as requested.
