How to configure digital products?
9 years 1 month ago #278825 by xxxcrow
I need to make digital products shop,
Something like as lazypay
I need to have product, which you buying them you getting different URLs or files or images
(Example(steam or PS4 accounts shops): megakeys.ru )
9 years 1 month ago #278832 by nicolas
HikaSerial allows you to attribute a unique serial number for each purchase of a specific product, and also has the possibility, via plugins, to generate a unique image (including the serial number, texts of the order, a barcode of the serial, etc) on it, and even recently PDFs files.
www.hikashop.com/extensions/hikaserial.html
The following user(s) said Thank You: xxxcrow
Time to create page: 0.042 seconds
