Product description not showing
8 years 11 months ago #284568
by norgan
Product description not showing was created by norgan
buzzinga.com.au
-- Joomla version -- : 3.8.2
-- PHP version -- : 7
-- Error-message(debug-mod must be tuned on) -- : nill
It's turned on and i can see it in code when i inspect but it won't show. I'm using helix3 template. Funny thing is if i go to brands, then click the same products it shows just fine.
Not working:
buzzingahoney.com.au/store/product/1-buzzinga-breeze-suit-white
If you change styles from hood to round or the size then products will display for some but not others.
Not working:
8 years 10 months ago #284591
Replied by nicolas on topic Product description not showing
I don't see what you mean. I've looked at the link you gave and without changing anything the description displays fine:
monosnap.com/file/r0vjlyvcWJbGd0Wf2gU3ZfupjPBW8j
Usually, when you have some area of the interface not showing in some cases with the characteristics selection, it's linked to modifications done in the view overrides of the product page layout that weren't done properly (either on your end or directly in the template)
