some add to cart buttons do not navigate to cart
8 years 8 months ago - 8 years 8 months ago #290147
by katrowen
some add to cart buttons do not navigate to cart was created by katrowen
-- HikaShop version -- : 3.3.0
-- Joomla version -- : 3.8.6
-- PHP version -- : 7.0.28
-- Browser(s) name and version -- : Firefox 50.0.1
Since the update, I have noticed some issues. Some (only some) 'add to cart' buttons on the detail page , add the product to the cart, but doesn't navigate there so a visitor doesn't know if it was added unless they go to the cart directly from the Cart button in the navigation. Oddly, other products do, so it isn't a global configuration issue. What can be causing this?
Any suggestions would be appreciated.
Last edit: 8 years 8 months ago by katrowen. Reason: Resolved items 2 and 3
8 years 8 months ago #290165
Replied by nicolas on topic some add to cart buttons do not navigate to cart
Turn off the "add to cart legacy" setting of the HikaShop configuration and make sure that the "hikashop cart notify" plugin is deactivated in the Joomla plugins manager.
That should then do it.
Time to create page: 0.040 seconds
