Is there any way to add or remove product manually using AJAX
- manoj.infowind
8 years 7 months ago #290713
by manoj.infowind
I want to know way I can add an item to cart manually using AJAX, and get modules corresponding modules to be refreshed automatically using AJAX.
8 years 7 months ago #290716
Replied by nicolas on topic Is there any way to add or remove product manually using AJAX
You want to use the window.hikashop.addToCart and window.hikashop.deleteFromCart functions that you can find in media/com_hikashop/js/hikashop.js
These functions automatically refresh the cart modules on the page so you don't have to worry about that.
- manoj.infowind
8 years 7 months ago #290795
by manoj.infowind
Replied by manoj.infowind on topic Is there any way to add or remove product manually using AJAX
Is there any way I can have "Add to Cart" button instead of "Choose option" in case of product option for "Gift Wrap", as it require one additional step for customer to add item to cart.
Is any I can have "Add to Cart" button instead of or with the "Choose option" to add specific item to cart with default value of option.
8 years 7 months ago #290796
Not with just the options.
You would have to edit the view file displaying the add to cart button to add hidden input fields similar to the input fields for the options on the product page so that the javascript add to cart would be able to take it into account.
- manoj.infowind
8 years 7 months ago - 8 years 7 months ago #290848
by manoj.infowind
Will it be not a great feature to give ability "Add to Cart" button along with the "Choose Option" button that make it easy to add item to cart with default option value.
Hope you like the idea.
Last edit: 8 years 7 months ago by manoj.infowind.
8 years 7 months ago #290858
Wouldn't it be better in that case to have the options directly on the listing in that case ?
- manoj.infowind
8 years 7 months ago #290923
by manoj.infowind
No because in that user have to do two selection like quantity and option. I feel user wont like that.
8 years 7 months ago #290933
For your case, maybe, but I'm talking about any kind of shops you could make with HikaShop. When we add a feature, we need to think about the big picture.
- manoj.infowind
8 years 7 months ago #291006
by manoj.infowind
BTW I have implemented it on my site.
Thanks for support.
Thanks for support.
