Hide a joomla module with display product page
8 years 6 months ago #291008 by francota
-- Joomla version -- : 3.8.6
Hello
I have a module that it is associeted just with one menu but now it comes out with single product.
I dont understand why
You can see at this url www.newescrowenergy.com/test01/la-chia/prodotti-chia/oli
If you click one one of those product it shows a module below, I dont want it...how can I solve??:dry: :dry:
The image shows the module that I want to hide
Frank
8 years 6 months ago #291027 by renem
Regular Labs Advance module manager does the trick.
8 years 6 months ago #291047 by francota
But I need the pro version to work with hikashop product
Or not??
8 years 6 months ago #291049 by renem
The free version supports URL (regular expressions) so this is possible to assign a module to a specific part of an URL.
8 years 6 months ago #291048 by Jerome
You will need to use "advanced module manager" for such kind of restriction on the display of Joomla modules.
Since modules are displayed by Joomla (and not HikaShop) ; there is nothing to do in HikaShop for that.
That component provide specific features in its "pro" version but even with the "free" one, you have features which can allow you to do what you want to do (using generic url features)
8 years 6 months ago #291064 by francota
Thank you both
I will try that, but for now I noted that there is a big problem with that module.
Infact I completely deleted it but It still appears below the products.
It is very strange :blink:
It could be depend on the import hikashop from other website as I discussed in this topic:
www.hikashop.com/forum/install-update/89...-to-another-one.html
Thanks Frank
8 years 5 months ago #291111 by francota
OK I solved
That module came from a configuraiton in hikashop tab view>product options.
Frank
Time to create page: 0.212 seconds
