Do not display Base Currency on Product Listing
8 years 4 months ago #294698 by wooservers
-- HikaShop version -- : 3.4.1
-- Joomla version -- : 3.8.1
-- PHP version -- : 7.1
We would like to show products only in their own Currency and hide Base Currency on Product Listing.
There is a very old discussion about modifying code in Views >> Product Listing.
However, the code now is different and old patch can not be used.
Can you advise how to modify the code so that only product's own currency is shown both on Product Listing and Checkout?
www.hikashop.com/forum/checkout/866056-d...eir-currency-of.html
8 years 4 months ago #294743 by nicolas
The piece of code mentioned on that other thread is still the exact same in product / listing_price.php:
if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_value_without_discount_with_tax,$price->price_currency_id); } if($this->params->get('price_with_tax') == 2) { echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax') == 2 || !$this->params->get('price_with_tax')) { echo $this->currencyHelper->format($price->price_value_without_discount,$price->price_currency_id); } if($this->params->get('price_with_tax') == 2) { echo JText::_('PRICE_AFTER_TAX'); } if($this->params->get('show_original_price') && !empty($price->price_orig_value_without_discount_with_tax)){ echo JText::_('PRICE_BEFORE_ORIG'); if($this->params->get('price_with_tax')) { echo $this->currencyHelper->format($price->price_orig_value_without_discount_with_tax,$price->price_orig_currency_id); } if($this->params->get('price_with_tax') == 2) { echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax') == 2 || !$this->params->get('price_with_tax') && !empty($price->price_orig_value_without_discount)) { echo $this->currencyHelper->format($price->price_orig_value_without_discount,$price->price_orig_currency_id); } if($this->params->get('price_with_tax') == 2) { echo JText::_('PRICE_AFTER_TAX'); } echo JText::_('PRICE_AFTER_ORIG'); }
so I don't see why the patch couldn't be used anymore. Did you get an error when you tried ? Which one ?
8 years 4 months ago #294776 by wooservers
and if we create a Module for "Product Listing" to be used with HikaMarket Vendor List, we also use "listing_price.php" or some other file?
sethealth.ru/список-продавцов/vendor/show/6-linda-cakes
here it shows Base currency "1 300 Баллов" and then in brackets the currency that we want to display: (1 300,00 РУБ)
8 years 4 months ago #294785 by Jerome
The product listing module under the vendor page is still a product listing.
If you create a menu or a module for a product listing, it will use the same HikaShop content. The place where you place the module doesn't matter but the module/menu settings do.
8 years 4 months ago #294959 by wooservers
but why replacing code doesn't help then?
8 years 4 months ago #294980 by nicolas
So do you mean that it works fine for other products listings and not for that products listing on the vendor page ?
I suppose that it doesn't work anymore because probably the modification you're doing is not the one you want to do.
For what you want, you need to change the code:
if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format(@$price->price_value_with_tax,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format(@$price->price_value,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } if($this->params->get('show_original_price') && !empty($price->price_orig_value)){ echo JText::_('PRICE_BEFORE_ORIG'); if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value_with_tax,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } echo JText::_('PRICE_AFTER_ORIG'); }
if(empty($price->price_orig_value)){ if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format(@$price->price_value_with_tax,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format(@$price->price_value,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } } else { if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value_with_tax,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } }
Please note however that such customization is outside of the support we're supposed to provide. We can give hints but it's up to you to do such code modifications or hire someone to help you with them.
