products missing
8 years 3 months ago #295437 by iwallace
products missing was created by iwallace
-- url of the page with the problem -- : kuruvita.com.au/index.php/shop
-- HikaShop version -- : 3.5.0
-- Joomla version -- : 3.8.10
-- PHP version -- : 7.1
Since updating joomla a couple of days ago - all of my products have disappeared!
has anyone else experienced this?
how do i fix it?
8 years 3 months ago #295444 by Mohamed Thelji
Replied by Mohamed Thelji on topic products missing
Can you download the last Hikashop version through our website, install it and test it again ? Thank you.
Best regards,
Mohamed Thelji.
8 years 3 months ago #295503 by iwallace
Replied by iwallace on topic products missing
I did have 3.5 installed - but as requested i downloaded and installed from your website - still no products
what next?
8 years 3 months ago #295504 by Jerome
Replied by Jerome on topic products missing
Next is to follow the steps explained in that pined thread of our forum ; more specially the parts regarding the view overrides that you will have to delete.
www.hikashop.com/forum/install-update/89...-upgrade.html#294471
8 years 3 months ago #295529 by iwallace
Hi Jerome
thanks for the help
i was able to complete step 1 and 2 in the link you posted and the products are back
step 3 and 4 - i couldn't match / find the code i was supposed to replace
im a bit worried that i have only half fixed it?
what do i do about steps 3 / 4
can you please advise?
thanks
8 years 3 months ago #295530 by nicolas
Replied by nicolas on topic products missing
The code changes in that post are already in the 3.5.0 so you should already have them.
So if you still have the issue even though you're using the 3.5.0, then there is only one thing to check, and that is the important note of the step 1 of that post.
So check if you have the file templates/YOUR_TEMPLATE/html/com_hikashop/category/listing.php ( the override of the view file category/listing.php ). If you do, rename it or apply the patch of the step1 to it, and that should definitely fix the problem.
