No products are displaying after PHP upgrade
8 years 1 month ago - 8 years 1 month ago #298691 by allanb
-- HikaShop version -- : 4.0.0
-- Joomla version -- : 3.8.12
-- PHP version -- : 7.2
-- Browser(s) name and version -- : Chrome Version 69.0.3497.100 (Official Build) (64-bit)
-- Error-message(debug-mod must be tuned on) -- : No error message
I had to upgrade my PHP version from 5 to 7.2. After the upgrade none of my products will display in the frontend. I get a Http error 500 in the backend when trying to edit a product.
I have no idea where to start looking. Any help will be appreciated.
After turning on debug mode in Joomla I get these error messages when trying to display a product.
Warning: count(): Parameter must be an array or an object that implements Countable in /home/yourehom/public_html/plugins/arkevents/autostylesheetfilter/autostylesheetfilter.php on line 50
Warning: count(): Parameter must be an array or an object that implements Countable in /home/yourehom/public_html/plugins/arkevents/autocssfilter/autocssfilter.php on line 46
Last edit: 8 years 1 month ago by allanb.
8 years 1 month ago #298692 by nicolas
First, your version of HikaShop is probably not 4.0.0, since your subscription expired a while ago.
So you're using an old version of HikaShop, which wasn't made to support PHP 7.2 as PHP 7.2 wasn't released yet at the time we worked on the release of HikaShop you're using.
So it's normal you would get errors.
On top of that, your old version of HikaShop also doesn't support the recent versions of Joomla. And the products missing from the frontend is a typical issue of using an old version of HikaShop with a recent version of Joomla as they aren't fully compatible:
www.hikashop.com/forum/install-update/89...-8-9-10-upgrade.html
Updating to the latest version of HikaShop will probably fix all your issues.
Time to create page: 0.041 seconds
