Pagination not working the right way
- daveydimwit
7 years 7 months ago #304760
by daveydimwit
Pagination not working the right way was created by daveydimwit
-- HikaShop version -- : 4.0.2
-- Joomla version -- : 3.9.3
We have an issue with displaying results from the search filter. When we have over 80 products, HikaShop displays only a page result. For example, we get the message - Results 1 - 50 of 103 but there are no pagination to check remaining products.
We have pagination enabled already and we are not displaying random items. What could be the issue and what do we need to modify to get the desire result.
You can replicate the issue by going to the link submitted, selecting a category from the website and clicking search.
FYI, Infinite scroll works well when it is used but normal pagination does not work well.
7 years 7 months ago #304777
by Philip
Replied by Philip on topic Pagination not working the right way
Your root issue come from your frontend template (or maybe a custom ?), see my screenshot :
image missing https://i.imgur.com/wEDIecb.png
When I remove the command you have as expected your HikaShop pagination.
Hope this will help you.
The following user(s) said Thank You: daveydimwit
Time to create page: 0.154 seconds
