- Thank you received: 14236
error 404 on infinite scroll product listing after uptdate to 4.1
I tried with port 22, but it doesn't work either:
monosnap.com/file/H6wQLqIfGNnGzBBCTIxUVg20bbjlLi
Could you double check the FTP credential and send them again via our contact form with a link to this thread ?
nicolas wrote: Hi,
Hi, i ask admin he said - you should use ftp client to connect server for example Filezilla and etc
I sent you new password on to you email.
I tried with the new credentials you provided, but I'm still not able to access your FTP server. And I do use Filezilla to connect to it since the first post of this thread.
nicolas wrote: Hi,
we cheked again and repaired connection on 21 port. Now it should work with same login and pass.
Please try it again. Sorry for inconvienice!
I'm sorry but I'm not able to connect to the FTP on port 21:
monosnap.com/file/6qZEZ3OczgbvPOcdtEbFl8c7szpJeK
nicolas wrote: Hi,
you used wrong ip
ip is 185.120.78.239
Well, I used the IP address you gave in your last email to me:
monosnap.com/file/IY5tGytf7MGjD3ojIQsHGYh200vmg8
But anyways, I'm now able to connect to the FTP, so I'll be able to debug the issue. I didn't had the time today as it was quite a busy day with support but I'll look into it tomorrow.
I found the issue thanks to the FTP access and added a patch for it.
I had to replace the code:
I've added the patch on our end too.
