- Thank you received: 1
Product listing module has gaps
7 years 2 months ago #310224
by Extrapet
Product listing module has gaps was created by Extrapet
euro-oes.show/index.php/nl/outdoor
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.11
my module " product listing" shows all products in the selected categorie, but in the rows & colums of products it shows 2 'blanc fields" and just moves the products.
In Safari it looks OK- no blanc fields-, but in Chrome and Explorer/ Edge the products are shifted and the sequence order is messed up.
I tried all kind of following orders; sometimes just 1 product field is blanc but in most options leave 2 products blanc. (order on price, name, etc)
There are no 'unpublished' products,
I cannot do any setting in the menu.
Under product I don't see any option to change the following order
in the active module "product listing" for this category I tried all options without succes, and put it back to "standard" now.
I just want to have the rows filled with 3 products on each row, without any blancs.
what should I change?
7 years 2 months ago - 7 years 2 months ago #310228
by p30yaran
Replied by p30yaran on topic Product listing module has gaps
hello,
Please add css code to css file and cache browser clear
then see the website
.hikashop_product_column_3 + * { clear: both; }
Last edit: 7 years 2 months ago by p30yaran.
7 years 2 months ago #310227
by Jerome
Replied by Jerome on topic Product listing module has gaps
While all your images are 1000x664 ; you have one image with the size 1000x666.
That little gap is affecting the size by 0.3px in Chrome and that's why you got your problem with the grid.
You can see to use the exact same size for your images or activate the "height consistency" option in your product listing menu.
The following user(s) said Thank You: Extrapet
7 years 2 months ago - 7 years 2 months ago #310256
by Extrapet
Replied by Extrapet on topic Product listing module has gaps
Thanks Jerome, activated the "height consistency" and it's solved!
Last edit: 7 years 2 months ago by Extrapet.
