Linking poduct thumbnails to Products
7 years 1 month ago #311912 by Vector
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.10
-- PHP version -- : 7.3
Hi , Rather than only the title of the product linking to the product detail page, could you please give me an insight into how to make the actual thumbnail link to the Detail page... thanks
7 years 1 month ago #311929 by nicolas
There is already a link on the product image on listings. So there is nothing to do in HikaShop for that.
You have some custom CSS coming from your template in the file :
/templates/jsn_glass_pro/ext/hikashop/jsn_ext_hikashop.css
In it, you have this CSS:
.hikashop_products_listing_main .hikashop_subcontainer .hikashop_product_image:before { content: ""; position: absolute; width: 100%; height: 100%; left: 0; top: 0; z-index: 99; background: rgba(0,0,0,.6); visibility: hidden; opacity: 0; filter: alpha(opacity=0); -ms-filter: "progid:DXImageTransform.Microsoft.Alpha(Opacity=0)"; transition: all .3s ease-in-out; -moz-transition: all .3s ease-in-out; -webkit-transition: all .3s ease-in-out; }
which does the hover effect on the product image and prevent the link on the image to work properly.
I would recommend to report the issue to your template provider support and see with them what they recommend to fix that.
7 years 1 month ago #311976 by Vector
Thank you Nicolas, All working. Relsolved
