Characteristics problems in backend as frontend
6 years 6 months ago - 6 years 6 months ago #317618 by webmasterab
-- HikaShop version -- : 4.2.3
-- Joomla version -- : 3.9.16
-- PHP version -- : 7.3.12
I import my products using a CSV file.
This went well until today.
suddenly it no longer works.
If I then create the variable in the backend I can click it but nothing is done with the information.
The price is not adjusted etc.
If I set the variable to standard in the bakcend, it will show the wait button because the stock is 0.
I put another variant on standard and I want to choose the variant without price and which is set to 0, nothing happens frontend.
It is also the case that if I choose 75 C and I add it to the cart, a completely different product is added to the cart
This is the default value
Last edit: 6 years 6 months ago by webmasterab.
6 years 6 months ago #317629 by nicolas
I got your two links before the CSV import and after the CSV import. But I don't see any difference. In both case, I see the add to cart button and the contact us button:
monosnap.com/file/0Cnv2ZUfHVjzEc4oNHSDTtHhtsASTS
monosnap.com/file/gQta0PN0VDkcGZrhDltg3ziIzEbtQ2
Now from your screenshots here, I can't say what product you're using for your example here. So I can't check on your website.
It would be great if you could provide:
- screenshots of all the settings of the product and of the settings of the variant with the issue
- screenshots of the issue on the frontend for that same product
- a link to that product on your frontend
That way, we can have a clear overview of the situation and check what's going on.
6 years 6 months ago #317630 by webmasterab
I'm going to work with it.
But it is not more convenient if you look in the backend.
It is now just more with the products before or after an import.
Have it now with other products.
Don't understand, I think I changed something that shouldn't have been done.
Can I just place it here or do you prefer it by mail?
6 years 6 months ago #317632 by webmasterab
I have now adjusted it to dropdown and then with a product with 0 stock I get the button waiting list.
If I use this and click cancel on the waiting list page, I will get the shopping cart button again, and if I add the default will be added.
Something is not going well somewhere, but where I have no idea
6 years 6 months ago #317638 by webmasterab
do you want screenshots of all settings?
Then I will arrange that
6 years 6 months ago #317640 by webmasterab
It is very strange.
Just checked a few things and the products just seem to work in the frontend.
The recently added products via import do not seem to be doing well.
I can't figure it out.
Can you reproduce it?
6 years 6 months ago #317645 by webmasterab
Have now added a product by hand and it does not work either
6 years 6 months ago #317651 by nicolas
I confirm that I don't have such problem on my end.
That's why I need precise information on the situation to be able to understand what's going on.
A backend access would be even better.
You can provide it along with a link to this thread via our contact form:
But I still need you to tell me which product is having the problem so that I can investigate.
6 years 6 months ago - 6 years 6 months ago #317652 by webmasterab
I sent you an e-mall
6 years 6 months ago #317755 by nicolas
I got the access but I'm not able to log to your backend with it.
Could you please double check the credentials and make sure they are working ?
6 years 6 months ago #317763 by webmasterab
6 years 6 months ago #317835 by nicolas
Thanks for the access.
I think I found the solution.
Change the code:
$this->values[] = JHTML::_('select.option', $key, $optionValue );
$obj = new stdClass; $obj->value = $key; $obj->text = $optionValue; $obj->id = 'hikashop_product_characteristic_'.$characteristic_id.'_'.$key; $this->values[] = $obj;
in the file components/com_hikashop/views/product/tmpl/show_block_charactersitic.php and it should work properly.
It actually comes from the way the Joomla library automatically generates the id of the radio button which conflicts with the id of the dropdowns and make it so the javascript of the characteristics switching system to behave differently.
This patch manually generates the id for Joomla so that it doesn't have to generate it automatically.
The following user(s) said Thank You: webmasterab
6 years 6 months ago #317874 by webmasterab
Thanks Nicolas for helping.
We are going to work with it.
maybe an idea to look at it to fix it for the future and that Joomla is not getting in the way of this anymore.
6 years 6 months ago #317879 by nicolas
Of course this fix will be added to the next version of HikaShop.
This bug has been there for years.
The problem is that it only happens in special conditions:
- you need several radio characteristics on the same product
- you need to have the id of the characteristic + the id of the value glued together matching with the id of another characteristic
That's why no one reported that issue so far
So don't worry, that bug won't happen again in the future.
6 years 6 months ago #317918 by webmasterab
That is amazing.
Then all searching has been in vain.
You are super busy with Hikashop and certainly in providing support.
Thank you for this
Time to create page: 0.113 seconds
