Two prices published at products
- nico.van.leeuwen
6 years 2 months ago #322368
by nico.van.leeuwen
Two prices published at products was created by nico.van.leeuwen
www.dekreij.nl/horeca/assortiment-geenpr...ir-van-delft-6x200gr
-- Joomla version -- : 3.9.20
-- PHP version -- : -
-- Error-message(debug-mod must be tuned on) -- : -
Customer is member of the user groups 'klant5' and '10475'. The group 'klant5' is a common group with a lot of customers. Groep '10465' is only for this customer with a lower price.
On the front end both prices are showed. It has to be only the lowest prijs. The configuration is set to 'lowest price'.
See attachment!
What's going wrong?
See attachment!
What's going wrong?
6 years 2 months ago #322369
Replied by nicolas on topic Two prices published at products
There is nothing wrong. The user will have access to all the prices his account and his user groups give him access to for the current currency.
Changing that to only take into account the lowest one would require some extra coding in the functions removeUneededPrices and _removePrices of the file administrator/components/com_hikashop/classes/currency.php
Note however that you might want that change, but that doesn't mean that it would be correct for anyone.
Some merchants can use the way it works now to set a base price for all the users, and then additional prices with min quantities for some user groups so that they would automatically benefit from reduced unit prices for bulk purchases for example.
Now maybe you want to take another approach to the situation.
If you don't want to remove the "klant5" user group from this user, because you use it for something else, I would recommend instead to create a discount for that product for that user with the value being the difference between the klant5 user group and the 10465 price and limit the discount to that user only.
That way, he'll get the extra discount on the product.
Time to create page: 0.144 seconds
