Error An element with the same alias already exists Error Saving
6 years 2 months ago #323592 by mohairbears
-- Joomla version -- : 3.9.21
-- PHP version -- : 7.4.9
-- Browser(s) name and version -- : Google Chrome
-- Error-message(debug-mod must be tuned on) -- : Error
Error Saving
Hi, I am getting an error when either trying to copy a product to create a new one and also when trying to create a completely new one? been using Hikashop for years and not nad this error before?
This is preventing us from adding new items to our shop?
6 years 2 months ago #323594 by nicolas
It means that you have another product with the same alias. So need to change the alias of that product you're trying to create/modify or the alias of the other product with that same alias and then you won't have that error message.
6 years 2 months ago #323634 by mohairbears
Hi Nicolas, That is not the case with this issue. I cannot put anything in, even something that I would never use and I still get the error message?
Rgds
6 years 2 months ago #323647 by nicolas
I don't see how that's possible.
If you think it really is the case, please send us a message via our contact form:
In it, include a link to this thread, a backend access and precise instructions to reproduce the error.
6 years 2 months ago #323674 by mohairbears
Hi, Investigated further and found I now have to type in the Alias myself where as before it would automatically use the product name and also change the variants as well which it is not doing?
Rgds
6 years 2 months ago #323683 by nicolas
You have the setting "Alias automatic filling" to control that in the HikaShop configuration. Maybe you changed it ?
3 years 5 months ago #352188 by DogPeople
I am having the same problem. What was the solution here?
3 years 5 months ago #352191 by nicolas
Well, it means you have two products with the same alias/name. So you need to make sure they are different and it will work.
3 years 5 months ago #352234 by DogPeople
Thanks. However, as mentioned before, I am building a website for a company that has 13 branches, all of which are independent vendors, and all of which sell the same items. So there will be 13 products with the same name.
When I created the copies, it automatically appended each copy with copyXXXXXX, and I assume that your system automatically generates unique numbers for that?
So yeah. I need to be able to create products that are the same, but I am leaving the system generated COPYXXXXX code after, so they ARE unique?!
Any way to work around this? Seems like a bug....
3 years 5 months ago #352236 by nicolas
You didn't mention anything about all this in your first message in this thread. Please understand that I answer to many people everyday and I can't keep track of who says what where.
When you use the "copy" button of the products listing, the system will generate unique product codes, adding the "copyXXX" at the end of the product code.
This error message is not about the product code, it's about the product alias.
As I said in another message to you here www.hikashop.com/forum/install-update/90...ion-help.html#352192 you need to have the first action of a mass action to use the product_code, which is unique, as the product_alias in your copies. That way, the system won't complain about the alias already existing.
2 years 7 months ago #360027 by NicoW
Hi, i created a new product and got the alias already exists error.
Now since i wronte a whole description of the product etc, i'm not fond of having to write it again.
I searched the database and could find the uploaded images but not the product page with the error so i could copy everything i already wrote.
Where can i find the page now it didn't save normally because of the error?
2 years 7 months ago #360028 by nicolas
Normally, when you save a product and there is an error, you should be redirected back to the product edit page with all the text you already entered in the fields.
So you shouldn't have lost anything.
However, if you then leave the product edit screen, you will loose what you have entered. You need to save again without any error for the data to be stored in the database and you can then find it in your backend.
2 years 7 months ago #360032 by NicoW
That's a very sad message to receive as the error message send me to prison and i did not pass start and did not get 500 dollars.
Now i will have to painfully write all texts again.
Hopefully this was a 1 time glitch.
