backend products: available stock is not automatically reduced
6 years 1 month ago - 6 years 1 month ago #324723 by Frank.Oehlen
-- url of the page with the problem -- : www.stattgarde.de
-- Joomla version -- : 3.9.22
-- PHP version -- : 7.4.10
-- Browser(s) name and version -- : Mozilla/5.0
Good evening!
I made a hika shop update and changed the PHP version. Since then the available stock is not automatically reduced anymore.
Is that kind of problem known to anyone? Or does anyone have an idea how to solve my problem.
Thanks a lot and greetings
Frank
Colonge | Germany
Last edit: 6 years 1 month ago by Frank.Oehlen.
6 years 1 month ago #324739 by nicolas
No one reported such issue so far. And we didn't change anything along those lines with the 4.4.0 either.
Are you sure you didn't had the problem before ?
Are your orders' status changed to confirmed after the payment ?
How did you configure the "update stock when order is" setting of the HikaShop configuration ?
Does the product you're using for your test has variants or not ?
Could you also do a screenshot of the settings under the System>Order statuses menu ?
6 years 1 month ago - 6 years 1 month ago #324844 by Frank.Oehlen
Thanks for paying me attention. My answers to your questions:
Yes – I am ? I used the 3.5.1 before and everything worked propper. We do sell ticktes for our events every year and they are limited. There haven’t been any problems before. I do have a mirror site which I used for some tests today. And it worked.
All orders' status are „confirmed“ after closing the ordering process. We do not use the order status „open/unpaid“ because our paying procedere is direct debit.
--> attachment
Some poroducts do have variants others not. But neither with nor without variants the stock is reduced.
--> of course, see attached
6 years 1 month ago #324849 by nicolas
I don't speak your language, but it seems that "confirmed" isn't enabled under the "invoice" column of the System>Order statuses listing.
If you hover on the title of the "invoice" column, it should tell that this column is used for stock management, and what that means is that when you have the setting "Update the product stock on confirmed status" activated, the stock will be decremented when the order changes status to one of the statuses enabled in that column.
I'm surprised you didn't get the same issue before the update as it's been like that for a long while now. But maybe you have an older version of HikaShop before the update and not the 4.3.0 ?
The following user(s) said Thank You: Frank.Oehlen
6 years 4 weeks ago #325141 by Frank.Oehlen
:woohoo: :woohoo: :woohoo: Thank you - thank you - thank you - thank you - thank you - thank you - thank you - thank you - thank you!!!!
Nicolas - you made my day!
The "invoice" column was the "problem" and now it works propper again!! THANK YOU!!
Greetings from Cologne, Germany
Frank
