Price for product not showing
6 years 2 weeks ago #325183 by iwallace
-- url of the page with the problem -- : www.richardbennett.com.au/index.php/hika...06-from-cape-to-cape
-- HikaShop version -- : 4.3
-- Joomla version -- : 3.9.22
-- PHP version -- : 7.3
My client has a number of types of prodyct - the photographs he sells work well - user selects a size and price is displayed
www.richardbennett.com.au/index.php/hika...45-mistral-9322-sh19
however for his books the price for my product idoes not show.
if it is placed in the shopping cart - the price can be seen when viewing the shopping cart.
how can i get the price to be displayed on the product info page?
thanks
6 years 2 weeks ago #325210 by nicolas
Hard to say. To me it looks like a customization issue.
Check if you have the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ on your website via FTP.
If you do, try renaming it and see if that helps.
If so, it means that the issue comes from one of the override view files in that folder that has been customized in a wrong way.
If you don't, then we'll need a backend access to check your settings and the situation to be able to say more.
